Max active jobs
scharette
Max active jobs
Post by scharette »
Hey there,
I've been using FFAStrans for 2 months and it's working very well ! Good job on the software !
I had to reinstall all the software on my laptop and now I'm not able to have more than one active job. I used to be able to get 4 jobs, since I reinstalled the software, I'm only able to get one. If I try to enter 4 in the box it goes back to 1,
Thanks !
Re: Max active jobs
Hm, I've never come across that issue. What about the slider, does it work?
Guest
Re: Max active jobs
Post by Guest »
Hey steipal,
I just realize that this setting is based on the number of core of your processor. I'm running FFAStrans on a Mac with VM Ware and there is a setting where your can set how many core you want, I did put 4 and it's back like it was before,
Thanks for your help !
