DVCPRO HD Support
vijm1972
DVCPRO HD Support
Post by vijm1972 »
Hi Steipal,
Please let me know if DVCPRO HD supported using FFAStrans, FFMBC has option to transcode to DVCPRO HD format.
Please suggest.
Vijay
Re: DVCPRO HD Support
FFAStrans has no built in DVCPRO HD encoder but you can try creating a "Custom FFmpeg"-preset or the try ffmbc using "Command executor" and use file name variables as input.
