Walkthrough of how to transcode new webm files to gif
ribblle
Post by ribblle »
I would like to use the watch folder features to detect when a webm file is downloaded, and convert it to gif. I'm a bit lost with the UI though. Thanks for reading and help mucho grande appreciated.
Re: Walkthrough of how to transcode new webm files to gif
Hi ribblle and thank you for using FFAStrans! :-)
What have you tried so far?
Normally it's a matter of adding a "Folder"-monitor, a "Stills"-encoder and a "Folder"-delivery.
ribblle
Post by ribblle »
I've done that, but I'm sad to say I'm not sure how to monitor a folder or do anything beyond adding those boxes to the workflow. http://imgur.com/JSDrhpa
You click on the names of the boxes to configure them. It's in the help text (F1). Have you done that?
ribblle
Post by ribblle »
Ah, the name not the box. None of the encoders seem to list webm or gif as a format. The custom FFMPEG encoder includes only audio and video options, rather then images which i expect gif would fall under.
I'm sorry but I'm on vacation and could not remember if the "Stills"-encoder supported gif or not, and it does not. Are you looking to convert the entire clip to gif-animation or just some selected frames like keyframes, or f.ex. frame each second or maybe just the first frame?
ribblle
Post by ribblle »
The entire clip, if that's doable.
So would that be a gif animation (one clip) or all frames converted to a series of .gif files?
ribblle
Post by ribblle »
1 whole webm clip converted to a single .gif clip. Enjoy your vacation, no rush.
Can you try and make a "Custom FFmpeg"-preset where you set extension to "gif" and deselect the audio and video codec checkboxes?
