When i set up my watch folders or i try to submit files to workflow i can't see my mapped networkd drives, i can see them fine in explorer but not in FFASTRANS.
Any idea?
Best regars
J.
can't see mapped network drives
Re: can't see mapped network drives
I'm unable to investigate that until next week but I'll give it a top priority.
Ok, I cannot seem to recreate the issue one Win10/8/7. FFAStrans sees my mapped drives on all three systems. Keep in mind that the file-requesters used in FFAStrans are just standard windows APIs so if it appears in exlorer, it sould also appear in the requesters, which basically are exlorer windows sort of.
Hi. What about connecting automaticaly to network CIFS/samba shares? Shares who need to enter a user and a password?
It is possible?
best regards,
laur
It is possible?
best regards,
laur
Currently there are no support for that in FFAStrans but in theory you could pull it of by adding a "Command executor"-node prior to the delivery node using the following command:
%comspec% /c "net use \\myserver\myshare /user:myusername mypassword"
