Same workflow as in last message...
Not able to force 16x9 on SD material
- Oceanwatcher
I am running some SD material through the system, and I checked the box in the MP4 delivery to force 16x9 on SD material. But it still comes out as 4x3 - at least when playing in VLC... Windows Media Player and QT don't even want to play the video, only audio
Regards,
Svein
Svein
Re: Not able to force 16x9 on SD material
Hm, ok?
I just tried to convert an old DV 4:3 clip and it works just fine. Forcing 16:9 gives 16:9. Leaving it gives original 4:3. It plays correctly in VLC and windows media player. Premiere Pro also sees the correct aspect for both converted clips.
What are the the width and height of your source video?
- Oceanwatcher
Hm, that's the same SD size as my test clips. 720x576 is among the resolution criterias that tells FFAStrans it's SD material, so your clip should definitely work. I don't suppose you have a short sample to share so I can investigate further?
- Oceanwatcher
