Remember clips
adelpino2
Remember clips
Post by adelpino2 »
I need convert all clips in to whatch folder repeatedly. After convert all clips i move all clips to other folder. But if i need convert the same clip again don't work the conversión. ¿I need change the name all time?
Re: Remember clips
Hi adelpino2
I'm sorry but I'm not sure fully understand your problem but let me try:
After conversion you move the original to another folder. But sometimes you need to convert that file again (?). So when you move the file back into its initial folder, your workflow does not pick up the file because it's already been converted?
adelpino2
Re: Remember clips
Post by adelpino2 »
I'm sorry for my English !!! .
Exactly , if I turn back a converted file does again.
Is there any way ?
Re: Remember clips
There used to be a function for this issue but it was wrongfully removed in the 0.6.1 release. It's back in the upcoming 0.7.0 release. Until then you have the option to reset workflow (right-click on the workflow). This will delete all history from the workflow.
adelpino2
Re: Remember clips
Post by adelpino2 »
OK,
thanks!!!
