Dual monitor
Dual monitor
Hi! In case of dual monitor configuration all of the dialogue windows appear on the first monitor. It's a little bit confusing if the main window is on the second monitor.
Re: Dual monitor
I don't think i quite understand what you mean
Do you have a screenshot that show the issue?
Re: Dual monitor
I've attached dual monitor screenshot - the main FFAStrans window is on the right monitor, when I click on node to open the menu, the menu window appears on the first (left) monitor.
- ffastrans02.PNG (113.8 KiB) Viewed 13505 times
Re: Dual monitor
Ah, I see. I'll have a look at it. Thanks for reporting:-)
Re: Dual monitor
Thank you for a such cool software!
Re: Dual monitor
This issue is now fixed in the new 0.7.2 release. The node windows will now appear right beneath the node.
