Hello Steipal,
I am trying live streaming using below FFMPEG command through command line, it's perfectly working. I am using YouTube to check my output.
How I can use below command in FFAStrans?
FFAStrans0.7.0_Win32\Processors\FFMpeg\ffmpeg.exe -re -i "D:\Movies\Test.mp4" -acodec libmp3lame -ar 44100 -b:a 128k -pix_fmt yuv420p -profile:v main -level 4.1 -s 1920x1080 -bufsize 3000k -vb 5000k -maxrate 6000k -deinterlace -vcodec libx264 -preset fast -g 75 -r 25 -refs 1 -bf 2 -f flv "rtmp://a.rtmp.youtube.com/live2/(Mykey)"
Please suggest.
Vijay
Live Streaming
Re: Live Streaming
Because of the way the "Custom FFMpeg"-encoder is built you cannot execute this encoder with the "-re" option before input "-i". So you need to do a "Command executor" for this one.
Changes to the "Custom FFMpeg"-encoder will soon come in order to solve these kind of scenarios.
Re: Live Streaming
Hi steipal,
si you already solve this problem with "Custom FFmpeg" processor (options before -i input) or the only way is still "Command executor"?
Many thanks,
mrazik
Many thanks,
mrazik
FFAStrans 1.2.2
Webinterface 1.2.0.4
8.00 GB RAM
NVIDIA Quadro K620
256GB SSD
1GB NIC
Windows 10 Pro 64b
8.00 GB RAM
NVIDIA Quadro K620
256GB SSD
1GB NIC
Windows 10 Pro 64b
Re: Live Streaming
In the current version of FFAStrans you still have to use Command Executor.
I made it for you:
where Stream Content is Command Executor with the following command:
%comspec% /C ""%s_ffmpegx64%" -re -i "%s_original_full%" -profile:v high -level:v 4.1 -refs 4 -b:v 5000k -maxrate 6000k -bufsize 3000k -ignore_chapters 1 -ignore_unknown -write_tmcd 0 -vf "sidedata=delete,metadata=delete,bwdif=mode=0:parity=0:deint=0,scale=w=1920:h=1080:flags=lanczos:sws_dither=ed,format=yuv420p,setfield=prog,setsar=1:1" -x264opts "keyint=25:force_cfr=1:deblock=-1,-1:aud=1:overscan=show:colorprim=bt709:fullrange=off:transfer=bt709:colormatrix=bt709" -color_primaries bt709 -color_trc bt709 -colorspace bt709 -color_range tv -field_order progressive -map_metadata -1 -metadata creation_time=now -c:a aac -b:a 384k -ar 44100 -ac 2 -f flv "rtmp://a.rtmp.youtube.com/live2/(Mykey)""
(Yes, I changed your command line a bit to make it look a bit closer to what the filter_builder would do in FFAStrans and I also changed the audio codec from MP3 to AAC 'cause encoding in MP3 in 2022 is a sin punishable by death not recommended).
