Video Stream Mapping Issue
vijm1972
Post by vijm1972 »
I have some source files in which some source files is having video Stream in 1st track and in some source files video Stream is having in last track. Using -map option I have created 2 watchfolders as per video Stream. Is it possible to create single watchfolder to process both the files?
My source files is in XDCAM HD 422 with 8 audio tracks.mov format and I am transcoding to same format using 2 audio tracks of source file.
Please suggest.
Vijay
Re: Video Stream Mapping Issue
Hi Vijay,
The next version 0.7.2 will have variables that tells you the stream number of the first video and audio stream. This can be used to create workflows that adapts to your particullar need by using the "Conditional"-node.
