User Variable in Filename Suffix
Locked
keitht
Post by keitht »
Is this a bug - or am I doing something wrong?
I am trying to submit a file (or files) have multiple encodes and add a suffix to the file name based on the encode node.
It does not seem to add the user variable to the suffix.
I have simplified the workflow - here is the setup:
https://www.dropbox.com/s/yvtcyzx96b2kkkc/1.JPG?dl=0
https://www.dropbox.com/s/79y18bmey4tc7dd/2.JPG?dl=0
(only allowing 2 urls - will follow up with another message with other pics)
Am I doing something wrong here?
Thanks,
-kt
keitht
Re: User Variable in Filename Suffix
Post by keitht »
Hm, that's a bit strange. I'll investigate and come back to you. Thanks for reporting! :-)
Ok, I can confirm now that it IS a bad bug and it will be fixed for the next release. I'm hoping to get it out very soon.
Thanks again for reporting! :-)
Oh, just realised that you can get around the bug by encapsulating your string with quotes ("):
"MINUScgop"
This bug is now fixed in the new 0.7.2 release.
keitht
Post by keitht »
Locked
