Help normal use
jeferson
Help normal use
Post by jeferson »
Help me Please!
I try to use FFAStrans in a windows 10 system.
Just like transcoding a file (avi) of directory X and put de result (H264) in other location.
Create a monitor processor, encoding processor e delivery to other directory, but not run!
You can send me a example of workflow to clear my mind?
Thanks!!
Re: Help normal use
Hi jeferson, welcome to the forum and thank you for (trying) to use FFAStrans! :-)
Just want to ask you a couple of questions regarding your non working workflow:
1. Have you connected nodes together? Like you see on the screenshot on this main web-site?
2. Have you configured the nodes? You do this by clicking the name of the nodes.
3. Have you saved your workflow? Your changes must be saved in order for it to work properly.
These questions might seem trivial but some people actually have problems with this. If you check all these questions, then I'd like to ask you to either export your workflow and send it to me (post@ffastrans.com) or post it on this thread.
-stipal
jeferson
Re: Help normal use
Post by jeferson »
I Send my workflow to your mail!
Thanks!!
jeferson
Re: Help normal use
Post by jeferson »
how man.. I don´t save my workflow!!!!
I'll try again!!!
Sorry.
