Expose first audio track channel count under media properties
azz
Post by azz »
Hi
Would it be possible to expose the 1 audio track channel count via the media properties to allow conditions to be made based on it. Currently only the total file channel count is provided.
thanks
Re: Expose first audio track channel count under media properties
I will take a look at how to expose unique audio tracks and channel counts. It's a bit tricky because there are is multitude of audio configurations.
azz
Post by azz »
Understandable amount the multitude of audio configurations, based on some of my past development work.
In this case specifically looking at the first track only, mainly to split the workflow based on either 2.0 or 5.1 being on the first tack.
cheers
