Can't populate viariable
Locked
rholm
Post by rholm »
I have a problem with the "Populate variables" processor.
I have created a user variable (%f_testvariable%), but it does not show up in the drop down inside the processor. If I press the ">" button next to the drop down it is there but the only option in the drop down is "None". Or am I doing something wrong?
THanks!
Robert
Re: Can't populate viariable
No, you're not doing anything wrong. It's a bug that has been addressed for the next release.
kibi
Post by kibi »
I found a workaround for this bug. It seems that only the first variable definition is ignored in dropdown lists. That's why you could add a fake variable (s___), and then all really used variables.
Alexander Sorkin
Locked
