Hi there,
first of all thank you for that great piece of software!
What I would wish for is a more detailed status information. The user who is waiting for his video to render would really benefit from an estimated remaining encoding time and the total encoding time.
Also a more accurate progress bar would be nice. I know that currently the progress bar shows the progress of all processors together. Most of the time especially When having just a basic Folder-->custom ffmpeg-->Folder setup the progress bar is kind of confusing.
This can also be seen in the Screenshot section on the main page. (http://www.ffastrans.com/screenshots/monitor_view.png) Although the encoder only transcoded 1 of 90 seconds the progress bar is already at like 90%.
Thanks and keep up the good work,
Tobi
More detailed status/progress
Re: More detailed status/progress
Hi Tobi, thank you for using FFAStrans and welcome to the forum!
Your request is noted. I know the total progress bar is a little confusing. There used to be a step status f.ex. 3/4 but it was changed to a bar. I'm thinking of revising it.
One of the variant how it might be is two different progress bars. One for the stages, and another for stage inner progress. And it's always up to you, how to make it finally.
Alexander Sorkin
