Saving of initial workflow position
kibi
Post by kibi »
It seems, that the position of workflow scheme is saved related to main window, but not to component canvas.
To reproduce the issue:
1) save workflow
2) change canvas size by widening left workflow pane - the diagram follows the canvas, as expected
3) double click at the workflow - the diagram would be reloaded in wrong position.
Alexander Sorkin
Re: Saving of initial workflow position
You are right...again ;-) Thanks for reporting!
kibi
Post by kibi »
Catching the bugs is my work. Please stop me, when it would be too annoying.
Alexander Sorkin
Alexander, you're a developers dream come true...;-) Please, don't stop reporting bugs!
kibi
Post by kibi »
Checked the bug in 0.7.6. The behavior had changed. Workflow scheme is saved not related to the main window, that's true. However, it does not linked to the field of view yet. After resizing&reloading it appears in random positions near the place where it is supposed to be.
Alexander Sorkin
Yes, that's true. It's better but not perfect. The whole code for dealing with positions, node-size, grid etc. is very "floating" in it's nature. In time I will revisit it once more but it wont be my top priority.
