Failing to Launch
Mentok
Failing to Launch
Post by Mentok »
Awesome prog thanks! Been using for a couple of weeks on my laptop with no issues so downloaded on my media server to set up some automations for a couple of cloud sync folders but am having a very basic issue where I can't actually get it to launch. It's not a new machine by any stretch of the imagination but has been a solid workhorse for years so hoping to be able to use it for some automation.
When i try to run (either normally or as admin) I get the windows 'thinking about it' icon on the pointer but it appears to crash out Windows Explorer (or at least hang for a few minutes).
Ali
Spec of Server:
Windows 10 Pro
AMD Turion II Neo N40L Dual-Core 1.50GHz
8GB RAM
Re: Failing to Launch
Hi Ali, thank you for using FFAStrans and welcome to the forum! :-)
Have you tried looking at your anti virus program (if you have one)? It's known to sometimes cause problems.
FFAStrans is developped on Windows 10 Pro but not tested with AMD processors.
Mentok
Post by Mentok »
Thanks for the swift response, I've made an exception on the AV so it is now launching but when I try to change any node settings it doesn't appear to save them & it also doesn't appear to be saving the workflow either. Hoping it is something fairly simple!
Cheers,
Ali
Mentok
Post by Mentok »
Moved the launcher and it is now saving perfectly, have a new problem now as no workflows appear to be working but going to have a play with security settings & permissions to see if I can work it out.
Cheers,
Ali
