Send e-mail: the transport failed to connect to the server
Post by taner »
i don't want to annoy you but maybe you have a tip/clue.
When using the "Send e-mail"-processor I always get this error: "the transport failed to connect to the server".
Port 25, no SSL, I can ping the server from the FFAStrans-machine. I've tried several machines running FFAStrans.
Our email-server works, we are using it for various other purposes.
Does FFAStrans need any credentials for the email-server? As far as I can see in the help of E-mail configuration I need username and password actually only if required.
Best
Taner
Re: Send e-mail: the transport failed to connect to the server
FFAStrans does not require any credentials if your e-mail server don't. The error message is generic and not directly related to FFAStrans. Are you running a Win2003 e-mail server? It might be some SMTP realy configuration. This is actually not my field of expertise. Transcoding is ;-) Have you tried sending using a gmail account?
I use the email-node all the time and it's working perfectly with the servers I have tested on. But, I don't have the option to test all kinds of scenarios. Search the error message on the web and you will find lots links describing various scenarios.
Post by taner »
Thanks for response. Our email-server is running with Linux. I will talk to our IT-guy.
Best
Taner
Post by taner »
Hi steinar,
After long time i've checked again. Problem is related to our virus-scanner whick blocks email-transport.
Email-notificication now works and I love it, especially in combination with variables.
Taner
Supercool! :D
