DV/DVCPRO processor error
kibi
Post by kibi »
I'm trying to convert MP4 video 768x576 (made by FFASTrans) into AVI format. The only option seems to be DV/DVCPRO encoder.
The workflow is rather simple: Input Folder - A/V Media - Resize - DV/DVCPRO - Target Folder.
But it fails to make video. All intermediate AVS is created and valid - I've checked it with AvsPmod. But the final step ends with "success" without creating target AVI file.
If I change encoder to MP4, the workflow produces target file.
There are some logs of ffmpeg for the DV/DVCPRO processor in the attachement:
20160707-122420-956-31887DCC4C3B.zip
(53.72 KiB) Downloaded 691 times
It seems, that problem is in built-in ffmpeg parameters.
Alexander Sorkin
Re: DV/DVCPRO processor error
Hi Alexander,
You're right, the DV/DVCPRO encoder was broken :-( It's now been corrected for the next release.
Thanks for reporting! :-)
PS: It was not a ffmpeg parameters issue.
