FPS Converter issue
kibi
FPS Converter issue
Post by kibi »
It seems that processor "FPS Converter" doesn't work as supposed.
My source files is XMF 23.976fps and I'd like to convert it to 25fps. When I add the filter 'FPS Converter" to the workflow, it inserts refference to ffms2.dll, LoadCPlugin("F:\FFASTrans_stage1\Processors\AVS_plugins\ffms2\ffms2.dll"), but doesn't use it in the code of the script. And the resulting file has unchanged FPS.
Have checked it with the option "Use motion compensation" in both states - no difference.
Alexander Sorkin
Re: FPS Converter issue
Hi Alexander, sorry for the delayed reply. I'm on my vacation right now so I'n not so active on the forum.
Anyway, the filter should not insert the ffms2 plugin, this is done by the "A/V Media"-decoder, which I assume you use prior to the filter? Can you please confirm this?
kibizoid@gmail.com
Post by kibizoid@gmail.com »
Confirm, the workflow includes A/V media processor, and works good in common - successfully transcode video, but FPS stays original.
Hi Alexander.
This is a bug that has been addressed in the upcoming 0.7.6 release.
kibi
Post by kibi »
Good news! Waiting for the 0.7.6 very much.
Alexander Sorkin
