Duplicating "dead lines" in Status Monitor
kibi
Post by kibi »
I run FFASTrans 0.7.5 from network shared folder in farm mode. And sometimes Status Monitor starts to show duplicating lines:
Restart of the Monitor helps, but not for a long time.
Alexander Sorkin
Re: Duplicating "dead lines" in Status Monitor
But they are not duplicates, they all have different status text. Is the workflow branched?
kibi
Post by kibi »
No, the workflow is not branched:
It's like "mouse trails". They are not real status lines, but very similar to bugs of drawing at canvas. They are not refreshing.
Only the original line continues to show changes.
Alexander Sorkin
That's odd. I haven't seen that before. Can you please download the latest version 0.7.6 available now and see if it helps. There are many bug fixes in that release, especially in farming mode.
kibi
Post by kibi »
Have updated to the latest version 0.7.6. The same situation. It's impossible to attach a video file, so please find it here: https://dl.dropboxusercontent.com/u/717 ... -32-00.mp4
And I've noticed a strange behavior of Status Monitor after upgrading. It doesn't show all the running processes from servers. I'm pretty sure that there are several (up to 6) processes running at every server. It could be easily seen with Sysinternals Process Explorer. But Status Monitor shows only some of them. I couldn't catch the logic of its choice :).
But there are a good news - when jobs become done, they are successfully shown in a log part of Status Monitor. Independently of the fact whether the process was shown or not.
May be it's necessary to clean some temporary after upgrade?
Alexander Sorkin
As I have written, I have never seen this behaviour before. From what kind of server share are you running FFAStrans in farming mode? It seems to be some kind of lag. Can you please stop all your workflows, make sure NO jobs are running and delete ALL files in the following folders:
FFAStrans\Processors\.cache\monitor\jobs
FFAStrans\Processors\.cache\tickets
When no jobs are running they should be empty.
kibi
Post by kibi »
I scanned the folder FFAStrans\Processors\.cache and it's sub-folders and found a lot of old files which creation/modification dates are not today date. Some of them were created several months ago. I tried to delete these obsolete files and folders and restarted FFastrans Monitor. And now it's working as supposed.
I have a backup copy of .cache folder and can send it to you for further investigations.
P.S. What about the system, I running FFastrans from:
Shared folder (SMB protocol) is at Windows Server 2012. The folder is at drive "HP Logical Volume SCSI disk device" (RAID). The network connection is 2 Gbit, so it should be fast enough.
Alexander Sorkin
So the issue was probably due to orphan files. But have caution when deleting files in the .cache folder. Not all old files are obsolete....
If you want you can zip the copied .cache directory to me and I'll have a quick look.
