Auto-Encode Image Sequence from watch folder
pcperformgroup
Post by pcperformgroup »
Hi Guys. I've ran into a bit of a problem. I'm looking to set up a multi-machine render farm to tackle After Effects renders. This render farm technique only works if the output is an image sequence. My problem is, I'm trying to find a way to then automatically encode this newly rendered image sequence into an movie file (.mov or .mp4) via a watch folder. Is this something that FFAStrans can help with? Thanks very much in advance!
Re: Auto-Encode Image Sequence from watch folder
Hi pcperformgroup, thank you for using FFAStrans and welcome to the forum! :-)
Please take a look at this and see if you can make sense of it:
viewtopic.php?f=5&t=170&p=250&hilit=sequence#p255
