Rename Nodes
dylanreeve
Rename Nodes
Post by dylanreeve »
It would be helpful to be able to rename nodes... Mainly for the purposes of status monitor, and text file generation.
In the status monitor when I have four branches all on my MP4 encoding stage, I can't easily tell which is which...
And similarly if I have all my branches to feed into some sort of logging node I can't easily determine which one is coming in - the %s_prev_node% variable which I could use is going to always be "Folder" I think?
Re: Rename Nodes
This option is already on the drawing board :-)
dylanreeve
Re: Rename Nodes
Thanks Steinar.
Re: Rename Nodes
The feature will be available in 0.8.0 :-)
kibi
Re: Rename Nodes
Post by kibi »
Do you have a roadmap for 0.8.0? Hope it's coming. :roll:
Alexander Sorkin
Re: Rename Nodes
Yes I hope to release it early february. It's taken longer than expected but there are also more improvements than I initially set out for 0.8.0, so...;-)
kibi
Re: Rename Nodes
Post by kibi »
That's really good news!
Are there any fixes for encoding stability?
Alexander Sorkin
Re: Rename Nodes
Do you mean actual encoding stability or other aspects of the program?
