Log lines hangup at Command Executor
kibi
Post by kibi »
I have several workflows with Command Executor as a last step - it executes Move or Delete command for the source files.
Sometime the workflows stay frozen at the last step, meanwhile the actual CMD processes have successfully finished (started by def_runner.exe).
30-08-2016 13-32-20.png (187.02 KiB) Viewed 11098 times
Bug found in version 0.7.6.1.
Alexander Sorkin
Re: Log lines hangup at Command Executor
So it's just an orphan line in the monitor view?
kibi
Post by kibi »
Yes, it seems to be an orphan line. With unknown origin :)
Alexander Sorkin
I'm still trying to sort that one out. Sometimes the monitor files are left behind and I'm not satisfied with that. Looking into it.
You can manually delete files in the "Processors\.cache\monitor\jobs" directory.
