Job Doesn't Start
diesus
Job Doesn't Start
Post by diesus »
Hi there!
Test.rar
(1.04 KiB) Downloaded 786 times
I am really interested in using this tool to convert my video to be uploaded to YouTube so I went off and rented a Windows VPS running a server 2012 R2 version. However, it seems that I can't make this tool work. I created a workflow, saved it, and tried feeding the folder a file. I also tried submitting a file. I attached my current workflow for reference.
Any help or suggestions on what I am doing wrong would be awesome! Thank you in advance! :)
diesus
Re: Job Doesn't Start
Post by diesus »
Okay, weirdly it started working. o_O
Hi diesus, thank you for using FFAStrans and welcome to the forum :-)
I think you should use absolute paths. Now you monitor "\Users\Administrator\....". I would use "C:\Users\Administrator\..." instead. Absolute paths are more reliable and I cannot guarantee that FFAStrans will work without it.
Post by taner »
Hi diesus,
hi Steinar,
I was about to write an answer because I had the same problem last week. Using an absolute path was the solution.
Best
Taner
diesus
Post by diesus »
Thanks guys! I updated the paths to make it more reliable. :)
