Additional slash when using %s_recursed_path%
McDuff
Post by McDuff »
Hi.
I'm testing out a workflow for recursive paths.
In the "deliveries -> folder" processor I am using
Folder [F:\Video ConvertedFolder]
Prefix [%s_recursed_path%\]
After the encode I get an error in the output saying the system cannot find the path - it's looking for F:\Video ConvertedFolder\\subfolder\filename.
There is no leading or following slash in the folder or prefix box (I double checked).
It looks as if it is adding a slash after the folder name and before the prefix name, resulting in an error.
Is there a way to prevent this?
Re: Additional slash when using %s_recursed_path%
Hi McDuff, thank you for using FFAStrans and walcome to the forum! :-)
The prefix and suffix is for file names, not paths. Use the folder field to insert the path variable:
F:\Video ConvertedFolder%s_recursed_path%
Don't add a "\" between the static folder and the variable.
McDuff
Post by McDuff »
Thank you, that makes sense!
