Basic workflow question
rholm
Post by rholm »
Hi again,
I have a pretty simple workflow that I just can't get to work as I want. The main problem seems to be with the mp4 encoder if using the x264 codec, I simply don't get any video at all (all black).
I have a high res video with 7 audio tracks.
Audio 1-6 are separate mono streams (5.1)
Audio 7 is a wav stereo track (mixdown)
I want to create an x264 mp4 file with Audio 7 as audio track. The audio format is not important, but it should be compressed. I have used the following workflow:
1. A/V Media - Decode audio only
2. ChannelMapper - Mapping channel 7 & 8 to track 1 + 2
3. Mp4 encoder (started with default settings)
My output is always black with no sound. If I change to other decoder, I get picture but no sound. I can continue to experiment with the audio mapping options, but I have had other workflows with the same result on the mp4 encoder (just blck output), anyone who can guide me in a new direction?
Re: Basic workflow question
Is it possible for you to export your workflow and send it to me and maybe share an example source video that initiates the issue?
estenmar
Post by estenmar »
Don't you need to have to decode the video in your A/V Media node? If you only decode Audio then it's not passing the video through to the MP4 Encoder.
Yes, that's true estenmar but he should still get a working file. It would however be without the video but it should not fail. If the MP4-encoder does not find any video it will try to create an audio-file. At the same time, I have recently discovered a bug in that method and it has been corrected for the 0.7.7 release. I would just like to see how his particular workflow behaves in relation to this particular bug.
rholm
Post by rholm »
I will send you the workflow. Unfortunately I can't send any video as I am not allowed to distribute. I will send you an export from MediaInfo. I am certain it all works just fine, but I am doing something strange...
Thanks again!!!
Try enabling full audio decode in the "A/V Media"-decoder. See if it helps.
