A/V Media"-decode big files
mberg
Post by mberg »
Hi
Is there a size limit for the A/V Media"-decode node? Have trouble with files bigger than 5 GB.
Get TTL and the process fails. Tried a 6 GB and a 11 GB file, the 4,7 GB completed without error.
Marius
Re: A/V Media"-decode big files
No, not that I know of. I tried an 19 gig file and it went through the decoder just fine. Are these large files on a fat32 drive?
mberg
Post by mberg »
No, the file system is NTFS. I will try some more files. See if i can recreate the problem with other files.
