Generate buffer video
mberg
Post by mberg »
Hi
I had a workflow that worked fine and now i suddenly get 2 errors:
Could not generate buffer video!
Could not recognize content in file!
Have anyone had this problem?
Marius
mberg
Re: Generate buffer video
Post by mberg »
Hi again
looks like it help when i reset the workflow!
Marius
Reseting the workflow should not have any effect on this issue. I'm thinking it might be loss of access to the work folder or not enough free space. Did you get that error on all files when it first appeared?
mberg
Post by mberg »
Hi
You are right, it happen again after the reset also. Yes, all files. even files i have tried before. It seems fine now. Will test more today.
Have 1 TB free on the disk that host the work folder.
Marius
Is the work folder on a network share? If it's not, check the drive for errors.
