Hi
I would like to test your tool.
I designed a simple workflow that choose between HD and SD et put the file in the right folder.When I submit a file in this workflow I have this error.
I tried many over workflows and it give me always de same error.
Can you help me please ?
AutoIt error
Re: AutoIt error
Hi Fred,
First, can you please export and send me your workflow? Also, what is your OS and how do you submit files? Last, does the workflow otherwise work as expected?
Re: AutoIt error
Thank you for your answer
I'am running windows 7 64 bits english with an admin account
I'am watching a folder but it dosen't pick up the file so I right click on the folder processor and click "submit file" then I have the error.
see the attached file
http://www.k-upload.fr/afficher-fichier ... e.xml.html
Re: AutoIt error
Ah, now I see what's wrong. You forgot to save your workflow! CTRL+S or rightclick->"Save workflow". I think that will do the trick.
Be aware of the asterisk (*) in the title window. It indicates a changed/unsaved workflow.
PS: The error you're seeing should not appear anyway and I will have a look at that.
