%s_original_path
BJRDUPLAIX
%s_original_path
Post by BJRDUPLAIX »
Hi Again :)
%s_original_path% works perfectly but %s_original_path~1% doesn't seem to work.
I use the last version (0.7.6.1)
Any Idea ?
Many thanks :)
Re: %s_original_path
Hm, It seem to be working in my version of 0.7.6.1. Are you sure you're using it correct?
BTW: 0.7.6.1 is not the latest. 0.7.7 is available now on the main web site. You should update :-)
