Impossible to create/see workflow
Hi.
I wanted to try the last updated version of FFAStrans, but I can't see or add or create any workflow in the workflow list...
If I try to import workflows, I can see folders, but Nothing more.
any ideas ?
any ideas ?
Re: Impossible to create/see workflow
Hm, that's strange. You might have a corrupt workflow. Can you please zip your "Workflows"-folder and send it so I can investigate?
Here is my workflow : https://we.tl/CMp0UAXJkI
(I use 0.7.6.1)
Let me know what you find
Thank you very much
(I use 0.7.6.1)
Thank you very much
I can't find anything wrong. I can import it, create new etc. It shows just fine. You only have this one workflow?
Yes. I can't create any new workflow. Apparently ...
But I think it's more about a display issue.
What kind of display issue? Are you working on some kind of remote desktop?
Actually,I think latest FFASTRANS is not working on Windows 10 (I tried 3 differents machine)
So I symply have to use the older version on windows 10
thanks
thanks
FFAStrans is mainly developped on Windows 10 so it's definately working. It's is probably a local issue. Have you tried with a fresh installation? Also, are you running FFAStrans from a shared network folder?
Hello.
I tried to use FFASTRANS on a fresh install of Windows 10 at work and at home. It didn't work.
(I'm running FFAStrans from the program_files folder)
I tried to install it on another computer at work with a "non-updated" version of windows 10 and on a fresh windows server 2012 installation.
It worked perfectly on both computers.
Older versions of FFASTRANS, worked everywhere.
I think something is going wrong with the latest versions of windows 10, not with FFAStrans
I'm running Win10 1607 and ffastrans works like it should on my installation. So I'm really not sure what the problem might be. Can you try running it from another folder than the program_files folder? FFAStrans is depending on 100% full read/write access to to the folder from which it's run to operate properly. I think the program_files has some restrictions built in.
