Avid MXF
shapiloff
Avid MXF
Post by shapiloff »
hello there.
nice software/greate job
how about to create an avid mxf preset with over then dnxhd codec (avid support xdcam and h264 for example)?
thx)
shapiloff
Re: Avid MXF
Post by shapiloff »
oh,
and add a typename property in project options) its extrimely usefull..
Re: Avid MXF
Hi shapiloff, thank you for using FFAStrans and welcome to the forum! :-)
I'm not quite sure I understood what you meant in your first post. Are you requesting XDCAM and h264 support in Avid-MXF type files/projects?
And when you write "typename", do you mean tape name?
shapiloff
Re: Avid MXF
Post by shapiloff »
oh, sorry.)
english is not my native language..
yes,
XDCAM (mpeg2) inside avid mxf container. not sure about h264, do not see it in raw2bmx options..
and yes,
"tape name"
Re: Avid MXF
Thanks, I will look into the XDCAM option and tape name. I don't think generic h264 is doable.
