I have a few different situation where I would like to read some metadata from a file.
Example 1:
I receive a high res video with multiple audio channels, and I want to create a low res proxy. I do however need to know which audio channel(s) that contain the mixed audio so I don't end up with a proxy with only surround channels as audio
Example 2:
I receive a high res video with multiple audio channels and I would like to export all audio channels separately. I have several workflows for this now depending on the channel order so the original has to be manually checked, but if I could read the channel position I could use one workflow for all videos and just name the output to the channel layout.
Example 3:
I have several audio tracks and would like to mux them together which I got to work thanks to your previous input here on the forum (thanks). I would however like to be able to add the channel position in the metadata?
Robert
