MediaInfo popping up and waiting to close
silverline
Post by silverline »
recently I have a problem with an older workflow. The workflow should analyse a media file and transcode it depending on its framerate to a mxf file.
The workflow works fine, but since I use Ffastrans with 2 new PCs I always get a MediaInfo popup after Fasttrans has finished analyzing the media file.
Unfortunately the workflow waits for me to close the windows before the next step is started - in my case the "indexing" comes next.
Is there somewhere I can stop MediaInfo showing the results?
Ffastrans (0.7.7) is started from a network drive and both PCs are configured to "share" the workfolder.
Thanks,
silverline
Re: MediaInfo popping up and waiting to close
Hm, that's strange, I've never seen or heard of this. MediaInfo is only shipped with the command line version. Can you please take a screen shot of the issue?
silverline
Ok,
stupid me! I updates Ffastrans to the latest version and copied my own processor goodies from the old version... then I copied the MediaInfo full version from a different folder and overwrote the command line version... sorry. Next time I will be more careful ;)
:lol:
