Custom ffmpeg Watermark
mrueben
Post by mrueben »
Whats wrong with this code
-i "C:\logo\logo.png -filter_complex" "overlay=10:10" -c:v libx264 -preset ultrafast -crf 20 -maxrate 5000k -vf scale=1280:720 -bufsize 1835k -c:a aac -strict -2 -ar 44100 -ab 128k -pix_fmt yuv420p
thanks for helping!
Re: Custom ffmpeg Watermark
Hi mrueben, thank you for using FFAStrans and welcome to the forum! :-)
Is this a test?
This is very wrong. I assume"C:\logo\logo.png -filter_complex" is not your input file? Word of advice; try your commands in dos before creating a custom preset in FFAStrans ;-)
mrueben
Post by mrueben »
Sorry for the question before thinking!!!! this now work in dos but how bring it in ffastrans?
ffmpeg -i C:\video\test.wmv -i C:\logo\logo.png -filter_complex "overlay=10:10" -c:v libx264 -preset ultrafast -crf 20 -maxrate 5000k -c:a aac -strict -2 -ar 44100 -ab 128k -pix_fmt yuv420p C:\video\out3.mp4
thanks for your time
marcus
mrueben
Post by mrueben »
for other user´s having the same problem here are the solution
-i "\\ipadress\ffastrans\Logo.png" -filter_complex "overlay=10:10" -c:v libx264 -profile:v high -preset ultrafast -b:v 5000k -minrate 5000k -maxrate 5000k -bufsize 5000k -c:a aac -strict -2 -ar 44100 -ab 128k
marcus
veks
Post by veks »
mrueben wrote: Tue Nov 29, 2016 4:25 pm for other user´s having the same problem here are the solution
marcus
When I try to add this to custom FFMpeg command I get "Encoding failed - No video or audio found in media."
Why is that so?
Hello Veks,
I think it's your path ("\\ipadress\ffastrans\Logo.png") which is bad...Where is your logo for watermark?
Hi Veks,
@momocampo i believe the path is fine, it is just a placeholder for some UNC path... As long as ffastrans is running as Application or as windows service including the correct credentials, access to the Logo.png will work.
@veks
please try this: in the Custom FFmpeg node, uncheck the Audio and Video Codec.
Explaination:
the ffmpeg command you want the Custom FFmpeg node to create is like
ffmpeg -i "%s_source%" -i "\\ipadress\ffastrans\Logo.png" -filter_comp....
But when you have audio and video checked, it will be created like this:
ffmpeg -i "%s_source%" ___AUDIO_VIDEO_CODEC_HERE  -i "\\ipadress\ffastrans\Logo.png" -filter_comp....
