just getting started error line 33391
Ray4x4x4
Post by Ray4x4x4 »
fresh install, simple setup. one watch folder, one DNxHD 1080i, 59.94, 145, 2 channel audio then one output folder.
Windows 2010 R2
Watch folder is on drive E:\drop, output is on drive F:\test
I get this error,
(file "C:\FFAStrans\FFAStrans0.7.7_Win32\FFAStrans0.7.7Win32\Processors\processors.exe"): Error: Array variable has incorrect number of subscripts or subscript dimension range is exceeded
Ray4x4x4
Re: just getting started error line 33391
Post by Ray4x4x4 »
ok so the server is running 2012 R2, sorry for the typo. Any chance of getting this thing working?
Ray4x4x4
Post by Ray4x4x4 »
Or let us take another tack. can anyone produce a working trans code path for windows 2012 r2?
Hi Ray4x4x4, thank you for using FFAStrans and welcome to the forum! :-)
I have seen this issue before and I'm currently investigating. Have you not been able get any workflow running on 20012 R2?
Ray4x4x4
Post by Ray4x4x4 »
Sorry I have not been able to get anything rolling.
I would assume that the 2012 would be the same as win 8.1. Does it work in 8.1?
Yes it works in 7, 8.1 and 10. Do you have full read/write access to the FFAStrans path and it's work folder?
Post by taner »
One of our transcoding-machines is running with Windows Server 2012 R2 too.
Location of FFAStrans and working-paths is our NAS.
This machine shares the same workflows as the other 4 transcoding-machines.
So far no problems with any workflows.
@Ray4x4x4: if it is ok for you I could try your workflow on our server-2012-r2-machine.
Best
Taner
Ray4x4x4
Post by Ray4x4x4 »
OK but it is about as simple as it gets.
DNxHD encoder to file storage. When I use direct submit, I get some form of processing happening then the error. I have tried network shares and local.
Is there some dependent windows processing software needed? Like as DhtmlEd or some such?
looks like xml will not upload to the forum, but here it is as text.
<?xml version="1.0" encoding="UTF-8"?>
<workflow>
<file>20161128161229.ini</file>
<data>0x5B67656E6572616C5D0D0A776174636865723D556E7469746C65640D0A666F6C6465723D0D0A776174636865725F69643D32303136313132383136313232390D0A536C6565703D350D0A44656661756C7420666F6C6465723D310D0A5072696F726974793D3220286E6F726D616C290D0A436865636B2067726F77696E672066696C65733D340D0A4C6173745F6D6F645F62793D41646D696E6973747261746F7240454449555346494C455345525645520D0A41766953796E7468204D543D340D0A41626265726174696F6E3D340D0A5B7661726961626C655D0D0A5B6D61696E7461696E616E63655D0D0A44656C6574655F636163686566696C653D340D0A6B6565705F616C6C5F776F726B6469723D340D0A6B6565705F6661696C65645F776F726B6469723D340D0A436C65616E75703D30343A30300D0A2E666C6973745F6167653D350D0A52756E3D323334353637310D0A5B7370656369616C5D0D0A46696C655F64656275673D340D0A44656275675F66696C653D433A5C464641537472616E735C464641537472616E73302E372E375F57696E33325C464641537472616E73302E372E375F57696E33325C50726F636573736F72735C2E63616368655C7766735C32303136313132383136313232395C6C6F67730D0A41766953796E7468204D543D340D0A41626265726174696F6E3D340D0A50726F7465637465643D340D0A50617373776F72643D0D0A5B757365725F7661726961626C65735D0D0A5B6D6F6E5F666F6C6465722032303136313132392D3039303033372D3336332D4539413434393532313046435D0D0A657865637574655F6F6E3D333830303838390D0A466F6C6465723D453A5C746573742064726F700D0A4163636570745F54797065733D0D0A44656E795F54797065733D0D0A44656E795F50617468733D0D0A4154545249425F524541443D340D0A4154545249425F415243483D340D0A4154545249425F5359533D340D0A4154545249425F48494444454E3D340D0A526563757273653D340D0A4C6F63616C697A653D340D0A4372656174655F466F6C6465723D340D0A44697253697A653D300D0A46696C654C696D69743D4E6F6E650D0A5B656E635F61765F646E7868642032303136313132392D3039303130322D3038352D4342363834383346444344375D0D0A657865637574655F6F6E3D333830303838390D0A466F726D61743D313038306935392E39340D0A4368616E6E656C733D320D0A444E7820747970653D3134350D0A6175645F626974733D31360D0A496E7465726C6163696E673D4175746F6465746563740D0A6175645F6C61796F75743D436F75706C65640D0A577261707065723D4D4F560D0A41766964456E61626C653D340D0A41766964436C69704E616D653D0D0A4176696450726F6A6563743D0D0A5B646573745F666F6C6465722032303136313132392D3039303133392D3234352D3835424241313132303742425D0D0A657865637574655F6F6E3D333830303838390D0A466F6C6465723D463A5C746573740D0A5375666669783D0D0A5072656669783D0D0A4F76657277726974653D340D0A556E697175653D310D0A436173653D4E6F6E650D0A44726F705F6E616D653D340D0A44726F705F6578743D340D0A5B454449555346494C455345525645525D0D0A576F726B20666F6C6465723D663A5C2E666661737472616E735F776F726B5F726F6F745C32303136313132383136313232390D0A</data>
</workflow>
Post by taner »
I've sent you my emailadress via private message. You can use it to send me your workflow. But I assume that it is no os-problem.
Could you please also zip your ffastrans-installation-folder and send it via wetransfer?
Best
Taner
Ray4x4x4
Post by Ray4x4x4 »
Hmm, I get error too large message attaching to this forum.
I have attached the ini file as a 7zip.
20161128161229.7z
(968 Bytes) Downloaded 995 times
