remote monitoring
Laurent.madjarian
remote monitoring
Post by Laurent.madjarian »
Hi and thx for your work !
What do you think about monitoring remotely the workflow , ie deploy a console log remotely ?
the idea is to monitor workflow with status, and provide heartbeat to inform user in case of crash.
This can be done with snmp or any network protocol.
Just a idea, but it could be great !
Re: remote monitoring
At some point in the future a REST API will be available for that kind of usage. I'm not sure when that will happen but after a longer delay, the work on the API is now back on the drawing board. Stay tuned.
mberg
Post by mberg »
We would also like support for remote monitoring.
A REST API for that would be great!
Keep up the good work! Use your software and have few problems.
Marius
