The process in not starting
Bogdan
Post by Bogdan »
Hi guys,
I created a short workflow, but the ffpemg process is not starting. Could you please advice me?
I'm using Windows Server R2 2008 and NAS storage for input/output.
Many thanks,
Bogdan
Re: The process in not starting
Post by taner »
Hi Bogdan,
Did you save your workflow after creating it?
And concerning the input-processor: have you specified which filetypes can be processed?
Best
Taner
Bogdan
Post by Bogdan »
Hi Taner,
I saved my workflow and I didn't specify any file to be denied.
Many thanks,
Bogdan
Post by taner »
Ok, what does the field "accept files" in the input-processor contain?
Bogdan
Post by Bogdan »
Hi Taner,
The accept file field is empty.
I followed the same instructions from this tutorial https://www.youtube.com/watch?v=RMISBx6iSeQ. I copied the file into watch folder and I expected to see the job processing in monitor window instead I can see no activity on that window. I'm using the last version available on the website 0.7.7.
Please see the workflow settings:
[general]
Watcher=Test
Folder=
Watcher_ID=20161206164740
Sleep=5
Default folder=1
Priority=4 (very high)
Check growing files=4
Last_mod_by=user@UXBVW
AviSynth MT=4
Abberation=4
[variable]
wf_size=105
Start_proc=mon_folder 20161206-165016-703-0AB72A6BBE4B
[maintainance]
Delete_cachefile=4
keep_all_workdir=4
keep_failed_workdir=4
Cleanup=04:00
.flist_age=1
Run=2345671
[special]
File_debug=4
Debug_file=C:\Users\User\Desktop\FFastrans\FFAStrans0.7.7_Win32\Processors\.cache\wfs\20161206164740\logs
AviSynth MT=4
Abberation=4
Protected=4
Password=
[user_variables]
[mon_folder 20161206-165016-703-0AB72A6BBE4B]
execute_on=3800889
Folder=C:\Users\User\Desktop\FFastrans\FFAStrans_Win32\Convert\Test\In
Accept_Types=
Deny_Types=
Deny_Paths=
ATTRIB_READ=4
ATTRIB_ARCH=4
ATTRIB_SYS=4
ATTRIB_HIDDEN=4
Recurse=4
Localize=4
Create_Folder=4
DirSize=0
FileLimit=None
proc_x=59
proc_y=43
Outbound=dec_avmedia 20161206-165050-922-6D02C6F1EDA4
[dec_avmedia 20161206-165050-922-6D02C6F1EDA4]
execute_on=3800889
Video=1
Audio=1
A_Decode=4
V_Decode=4
A_Method=Intelligent
V_Method=Intelligent
proc_x=216
proc_y=43
Outbound=avs_v_deinterlace 20161206-165107-828-3DBD6E18D018
[avs_v_deinterlace 20161206-165107-828-3DBD6E18D018]
execute_on=3800889
Deinterlac_type=YADIF
proc_x=374
proc_y=43
Outbound=enc_av_mp4 20161206-165124-515-B3026CD5EFD4
[enc_av_mp4 20161206-165124-515-B3026CD5EFD4]
execute_on=3800889
V_Codec=x264
V_Bitrate=15000
A_Bitrate=240
Faststart=1
force_16_9=4
Only_Audio=4
restrict=1
A_Samplerate=48000
M4V=4
Level=auto
Profile=main
Tuning=none
QSpeed=medium
ch_layout=stereo
proc_x=531
proc_y=43
Outbound=dest_folder 20161206-165335-734-B9D586D8284A
[dest_folder 20161206-165335-734-B9D586D8284A]
execute_on=3800889
Folder=C:\Users\User\Desktop\FFastrans\FFAStrans_Win32\Convert\Test\Out
Suffix=
Prefix=youtube
Overwrite=4
Unique=1
Case=None
Drop_name=4
Drop_ext=4
proc_x=689
proc_y=43
Outbound=
[UXBVW1021SMS01]
Work folder=\\IP ADDRESS\FFAStrans\Intermediate\20161206164740
Post by taner »
I had to change the input- and output-paths of your workflow (still remains local drive) but apart from that it works on my machine.
Only thing I see is that "Check for growing files" is not enabled.
Please check the box and try it again with a new file.
If you have already files in your watchfolder you can stop the workflow, reset and start it again.
Alternatively you can also submit a file manually.
This should always show whether your workflow works at all.
Bogdan
Post by Bogdan »
Hi Taner,
The problem is solved. It was a problem with my unzip tool.(some files were missing)
Thank you for your help,
Bogdan
