FTP delivery
mberg
FTP delivery
Post by mberg »
Hi
I am trying to use ftp delivering to transfer files to an another server. but i can not get it to work.
I am using ffastrans 0.7.7.
It will make an folder on the other server if i write in an folder that do not exsist in the path, but it will not transfer any files.
tried with different accounts. If i push the "path" button in the settings for the ftp delivery, i get access to the remote folder, so i know the username and password is ok.
Also tried to grant the account more permissions.
Marius
Re: FTP delivery
Hi Marius,
What do you mean by:
"It will make an folder on the other server if i write in an folder that do not exsist in the path..."?
It does not create any folders except if the original file has come from a recursed folder.
Have you tried other servers? I just tried this one: ftp://speedtest.tele2.net/upload/ and it works. Also, have you tried passive mode?
mberg
Re: FTP delivery
Post by mberg »
Hi Steinar
Think I found the problem. I have a watchfolder on the main folder "transcode" with the recurse mode set to "on". My structur is "transcode" -> then subfolder "folder1" - > then subfolder "folder2" -> then myclip.mp4. In this structur it will not transfer the "myclip" file, but if i move the "myclip" file to the main folder "transcode" , then the FTP delivery works..
Could you test on your side? Put a file in a sub folder of the watchfolder and try the FTP delivery.
Marius
Re: FTP delivery
Yes, I will take a look at the issue. Thanks for reporting! :-)
Re: FTP delivery
Hi Marius,
I can confirm the bug and try to fix it.
