Simply way to add filename to insert media png board
laso
Post by laso »
Hi everyone
I have a simple question, how to add basic info (file name length) to the static board png. I use insert media, which adds information boards before my file. I would like to add to this board automatically file name.
Should I use a custom AviSynth script, or is another simple way to do that.
My workflow look like this
Re: Simply way to add filename to insert media png board
Hi laso, thank you for using FFAStrans and welcome to the forum! :-)
Currently FFAStrans does not have inbuilt functionality to add text on top of video but I think you're on the right track by bringing up AviSynth. FFAStrans lets you extract lots of file/media information as variables that you can use to create a custom AviSynth-script. Take a look at the "Subtitle" function: http://avisynth.nl/index.php/Subtitle
laso
Post by laso »
thanks for the answer !
and a big thank you for a wonderful simple and powerful tool.
