Conditional Node: How many Audio Streams in original File?
Hi there,
just stumbled ´bout this problem:
I want to insert a conditional node which locates the number of audio channels in the original file. Example: DV-Files with two or for audio-Files. I want to convert these to different formats, some with 4 audio-tracks, some only with the first two audio-tracks depending on target-format.
ALL input is DV-material in .mov container
node-list test1:
1. Folder-Node
2. conditional-Node with %i_a_streams% IS = 2 THEN -> Encoder-Node A -> Output-Folder-Node
3. conditional-Node with %i_a_streams% IS > 2 THEN -> A/V-Media-Node All set to intelligent -> ChannelMapper-Node -> Encoder-Node B -> Output-Folder-Node
node-list test2:
1. Folder-Node
2. A/V-Media-Node All set to intelligent
3. conditional-Node with %i_a_streams% IS = 2 THEN -> Encoder-Node A -> Output-Folder-Node
4. conditional-Node with %i_a_streams% IS > 2 THEN -> ChannelMapper-Node -> Encoder-Node B -> Output-Folder-Node
ALL DV-Material is 2-Channel (stereo...) but I get only 4-channel exports - what do I do wrong?
regards,
tom
Re: Conditional Node: How many Audio Streams in original File?
Hi Tom,
The current version (0.7.7) cannot obtain the audio layout in a good fashion. The "%i_a_streams"-variable will tell you how many audio streams there are, not the channel count. Streams and channels are not the same. The new version (0.8.0) will have a variable for the total number of channels in the media but it wont tell you the audio layout.
In your node-list test2 you're using the "A/V Media"-decoder. It will ALWAYS give you ONE stream with 32 channels, so the conditional test must be done prior to the decoder.
What kind of encoder are you using?
Steinar,
thank you for this answer. It´s great news that 0.8 will have a audio channel-variable.
If I would have read carefully I should be aware of "streams" and "channels"... Sorry for that. It´s clear.
I wanted to encode to DV (DVCpro) (2 or 4 channels) and mpeg4 (2 channels only, kick channel 3 and 4 if present).
Regards,
tom
Hey Steinar,
I discoverd this variable: %i_a_channels% but it´s the same result...
tom
once again, the output in the FFAStrans Monitor is:
Conditional@machine : 1st evaluation of "%i_a_channels%>2" is "2>2" - does this make sense?
regards, tom
Yes it makes sense. The evaluation failed because the condition was not met. 2 is not larger than 2.
And I'm sorry to have misled you. I simply forgot the %i_a_channels% variable. My bad. But it does what you expect; counts the total number of channels regardless of the layout.
The current DV-encoder supports 2 or 4 channels. You just use the conditional to decide if your source has 2 or 4 channels and send them to each corresponding encoder with two different settings (2 and 4 channels).
Additionally, it may be easier if you send me or post the workflow and I'll have a look at it and see if it's valid.
