Windows 10 basic problems
pipuvic
Post by pipuvic »
Hi Forum. Hi Steinar,
I recently switched to Windows 10 with the workstation and now FFAStrans not even is showing a grid in the right window, so i guess something basically (graphics-related) is missing.. i can put nodes into it, but no lines between the nodes are shown.
I installed some redistributable visual c++ Files(x86), but it wont help.
Any suggestions on this?
Thanks in advance!
pipu
PS: all my other problems are on hold till this is resolved ;)
Kaffe, Junge. schwarz heiss und lecker.
Soffort
Re: Windows 10 basic problems
Post by Soffort »
I have Windows 10 and Windows Server 2016 and on both grid shows as expected.
Maybe you have accidentally turned the grid off? Right click on the (missing) grid...
pipuvic
Post by pipuvic »
Thank you for your Replies!
admin wrote: Wed Mar 29, 2017 12:16 pm Maybe you have accidentally turned the grid off? Right click on the (missing) grid...
Its a plain, new Installation of Windows and FFAStrans. i did nothing else than install, double-click the exe and rubb my eyes ;)
Its not only the Grid.. I am not able to draw Lines as i can not see anything except the nodes (when i made them..)
Soffort
Post by Soffort »
Maybe it depends to other system libraries or drivers? Did you try new video driver and windows updates?
Well that's weird... Are you using some kind of remote desktop or virtual machine? Do you have correct display drivers? Do you have anything that suggest your system is not "straight of the shelves"? FFAStrans is mainly developed on Windows 10 and I've never seen that problem. That said, FFAStrans has not the best gui engine in the world and I intend to address that at some point.
pipuvic
Post by pipuvic »
Thank you for your answers guys!
The workstation is not available atm. Next wednesday i ll step back to that topic, so i dont have any news yet.
A good hint is remote.. There was a teamviewer session opened IIRC.
No virtualization. Samsung 850 EVO in an HP ProLiant. Default windows graphic drivers. windows up to date.
i will report next week.
Thanks!!
pipu
pipuvic
Post by pipuvic »
wow. I just installed FFAStrans 8 on another Windows 7 Machine and its the same problem! So, i think its not related to the windows version..
On the left side there is no text, ergo no clickable icon. on the right there is no Grid. But the grid comes up if i place the first processor.
I installed MS Visual C++ 2015 14.0.23026 64bit and Visual C++ 2015 14.0.23026 32bit
Eh, I've never seen that one before :?: :o
Can you please zip the "Workflows"-folder and the Processors\ffastrans.ini file and send it to me?
pipuvic
Post by pipuvic »
There is no Worflows-Folder.. I made a zip with a screenshot and the ini. Sorry for the Delay!
Thanks a lot for any furher research.
ffastrans_error_empty.zip
(91.23 KiB) Downloaded 865 times
