Populate variables nodes don't save description/alt name
kibi
Post by kibi »
It's an old issue, as far as I remember, I meet it even at 0.6.
It happens only to Populate Variable nodes.
To reproduce:
1) Change the description of Populate Variables node (to "test") and save workflow
2) Switch to another workflow and then go back to the first one
3) Edit some parameters of Populate Variables, press Ok and save workflow.
4) Switch to another workflow and go back again.
expected: correct description "test"
in fact: default description
Alexander Sorkin
Re: Populate variables nodes don't save description/alt name
Sorry, unless i misunderstand the issue I'm not able to reproduce. The node correctly keeps the last midified name/description intact.
So this only happens with the "Populate Variables"-node?
kibi
Post by kibi »
As far as I know, it only happens with the "Populate Variables". Definitely.
The node fails to keep its description after any parameters (variables or values) was changed.
Alexander Sorkin
Ah, yes now I see the problem. I misunderstood you the first time but now I can recreate the issue. Thanks for notifying! :-)
Bug located and fixed.
kibi
Post by kibi »
That's great! It was hard to recreate for me as well. :)
Alexander Sorkin
