AVC stalling on
tzidore
AVC stalling on
Post by tzidore »
Hi
I have set up a watch folder and one of my colleagues drop a file like below into the folder, and the encoder starts but stalls at analyzing properties at 4/5.
The workflow settings are below the file info:
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4.1
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Format settings, GOP : M=2, N=24
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 1h 49mn
Bit rate : 15.6 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.301
Stream size : 11.9 GiB (91%)
Language : English
Encoded date : UTC 2017-04-06 03:41:08
Tagged date : UTC 2017-04-06 06:00:58
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
h264 encode
[General]
Watcher=01_Kollaborate_High
Folder=""
Watcher_ID=20170215085740
Sleep=30
Default folder=1
Priority=2 (normal)
Check growing files=4
Last_mod_by=gilyd@GILYDRENDER
AviSynth MT=4
Abberation=4
description=
[Variable]
wf_size=159.691875
Start_proc=mon_folder 20170215-090013-066-D4EB95DDDBD5
[Maintainance]
Delete_cachefile=1
keep_all_workdir=4
keep_failed_workdir=4
Cleanup=04:00
.flist_age=5
Run=2345671
[Special]
File_debug=4
Debug_file=C:\Program Files\FFASTrans\Processors\.cache\wfs\20170215085740\logs
AviSynth MT=4
Abberation=4
Protected=4
Password=
[mon_folder 20170215-090013-066-D4EB95DDDBD5]
execute_on=3800889
Folder=\\AVFS_SERVER\gilyd-ddp\10_Render_Jobs\01_Kollaborate_High
Accept_Types=*.mp4|*.mov|*.mxf
Deny_Types=
Deny_Paths=
ATTRIB_READ=4
ATTRIB_ARCH=4
ATTRIB_SYS=4
ATTRIB_HIDDEN=4
Recurse=4
Localize=4
Create_Folder=1
DirSize=0
FileLimit=None
description=Accepts *.mp4 *.mov *.mxf
proc_x=-17
proc_y=66
Outbound=dec_avmedia 20170215-090219-989-45FD27EBFAE8
growing_files=1
[dec_avmedia 20170215-090219-989-45FD27EBFAE8]
execute_on=3800889
description=Decoding videofiles
proc_x=223
proc_y=66
Outbound=avs_v_resize 20170215-090229-438-899799B7810C
Video=1
Audio=1
A_Method=Intelligent
V_Method=Intelligent
x64avisynth=4
force8bit=1
A_Decode=4
V_Decode=4
[avs_v_resize 20170215-090229-438-899799B7810C]
execute_on=3800889
Quality=Lanczos
Preset=HD 720 (1280x720)
Interlaced=4
Width=1280
Height=720
description=Resizes to 1280x720
proc_x=462
proc_y=66
Outbound=enc_av_mp4 20170215-090347-175-2355D549572F
[enc_av_mp4 20170215-090347-175-2355D549572F]
execute_on=3800889
V_Codec=MPEG4
V_Bitrate=3000
A_Bitrate=128
Faststart=1
force_16_9=4
Only_Audio=4
restrict=4
A_Samplerate=48000
M4V=4
Level=auto
Profile=auto
Tuning=none
QSpeed=superfast
ch_layout=1x2
description=Mp4 128 kbps slower encoding
proc_x=702
proc_y=66
Outbound=dest_folder 20170215-090543-182-5F9C97D5E4F9
audio_layout=1x2
interlacing=Autodetect
fields=Progressive
vid_width=%i_width%
vid_height=%i_height%
[dest_folder 20170215-090543-182-5F9C97D5E4F9]
execute_on=3800889
description=Output folder
Folder=\\AVFS_SERVER\gilyd-ddp\10_Render_Jobs\00_Output
Suffix=
Prefix=_%s_wf_name%
Overwrite=4
Unique=4
Case=lower
Drop_name=4
Drop_ext=4
proc_x=941
proc_y=66
Outbound=
[GILYDRENDER]
Work folder=s:\.ffastrans_work_root\20170215085740
[farming]
list=
include=1
Any idea why this happens and it doesn't complete the task. It has been running through the night.
Re: AVC stalling on
Hi tzidore, thank you for using FFAStrans and welcome to the forum! :-)
I think you need to share with me a sample that initiates the issue so I can investigate. In my tests your workflow is working just fine.
