Never ending "Check AviSynth script"
jfou87
Post by jfou87 »
Hello !
I had some troubles in my workflow.
We used FFastrans for a long time and since last week we experienced problems.
Here is the workflow : Folder->A/V media->ChannelMapper->Resize->Custom FFmpeg->Folder
This is always the same files in the input folder: Apple ProRes 422 LT. We're using this workflow to create a low resolution files and pushing on our website.
Now the problem: The FFAstrans is blocked at the same operation (node 2/6) and displaying "Checking AviSynth script" and also "Analyzing media properties".
Is there anybody already had this problem ?
I've tried to install the last version of FFaStrans, download latest FFmpeg and install latest version of AviSynth. But still don't work.
Thank you very much for your help.
Re: Never ending "Check AviSynth script"
Hi jfou87, thank you for using FFAStrans and welcome to the forum! :-)
Does this happen to all files? Also, can you please send me your workflow?
Post by taner »
Did you install visual studio 2015?
