Minimize to system tray
XStylus
Post by XStylus »
Hi there, thanks for making FFAStrans. I've only had a day to tinker with it but this looks like it would solve a lot of problems in my workflow.
A couple of quick questions -- Can there be a way for FFAStrans to be minimized to the system tray icon, rather than to the taskbar?
Secondly yet related to the first question, can there be a setting (perhaps a checkbox in the Options/Configuration window) whereby FFAStrans automatically launches minimized to the system tray?
And third, is there a way to set up FFAStrans to run as a system process? Currently I can set it to run automatically at startup when a user logs in, but this is no good for a headless system where a user rarely needs to log in.
Thank you!
Soffort
Re: Minimize to system tray
Post by Soffort »
For my opinion, it's very good request and I'll be happy about it! And next logical step - dividing software to server (as service) and control/view parts with remote access over the network. I hope, it can be possible in the future :)
Hi XStylus, thank you for using FFAStrans and welcome to the forum! :-)
I will take a look at your system tray request. It makes sense. Also, I have plans on making FFAStrans as a service.
XStylus
Post by XStylus »
Hi there!
Was just curious as to if, by any chance, this feature request was still on the radar. Thank you!
ouhhh it's a real good idea, don't know how I don't think about that early...
I use FFastrans as application and minimize will good really useful for me.
Hope it will be possible.
Cheers
Hi all, I'm sorry but i simply forgot this request, so thanks for reminding. You might also consider running FFAStrans as service. It works very well. Anyway, I will try and add system tray very soon.
