Monitor node can't see files if filename include semicolon
Soffort
Post by Soffort »
Subj :)
Monitor node can't see file if filename include ";" (semicolon). It is correct character in Windows OS filename. Sometimes used as emoticons "Fun video ;-).mp4", sometimes as list separator "composition - first; second; last.avi".
I am using the self-writed autorenaming and transliteration software, but it must be run before folder monitor.
Re: Monitor node can't see files if filename include semicolon
Hi Soffort, thanks for reporting! :-)
Have you checked "growing files" in the monitor? It might be related.
Soffort
Post by Soffort »
Yes, this problem with "growing files" option only. But I need this option, because some files uploaded from other sources over FTP or something like that.
The issue has been corrected for the next release.
