Frame Rate conversion: Access violation
Hi there,
another issue:
I Want to do a frame rate conversion from an 25fps AVI to 18fps h264 or dv/dvcpro (tested both).
i get a "access violation" on the encoder nodes.
Workflow is attached - maybe someone has an idea what I did wrong...?
thanks in advance,
tom
Scan_To_fullHD_4zu3_Centercut_MP418fps_AusZwischenspeicher_neu.7z
(1.7 KiB) Downloaded 819 times
Re: Frame Rate conversion: Access violation
Hi Thomas, sorry for the delayed reply. I have no problem with your workflow. Tested a few files and have no crash. Maybe you can send a short sample of one of your source files?
Soffort
Post by Soffort »
Do you have installed vc++ redistributate 2015?
sorry for late answer...
Yes, Vc000 2015 is installed. An issue?
thanks a lot,
tom
