I'm testing with FFAStrans 0.8.1 and I'm experiencing the following issue;
- Started from scratch.
- I created a workflow which uses two statics. %S_WATCHPATH% and %S_EXPORTPATH%, both target to a UNC network path.
- Everything runs fine.
- But when I try to edit the 'Populate variables'-processor, the GUI freezes and I have to force quit FFAStrans. The same issue occurs when adding a 'Populate variables'-processor to a brand new workflow.
Where are the statics stored?
GUI crashes on opening 'Populate variables'
bartcuijpers
- 20170719152439.zip
- workflow
- (1.21 KiB) Downloaded 765 times
bartcuijpers
Re: GUI crashes on opening 'Populate variables'
I found them in the ffastrans.ini file.Where are the statics stored?
I also noticed the issue only occurs when using more than one static;
[FFAStrans]
version=0.7.5
[user_variables]
S_test=\\nasmtr01.l1rtv.l1.nl\uitwissel$\MEDIA\Uitwissel_avid\FLIPIN\
S_TESTTEST=testCode: Select all
[FFAStrans]
version=0.7.5
[user_variables]
S_test=\\nasmtr01.l1rtv.l1.nl\uitwissel$\MEDIA\Uitwissel_avid\FLIPIN\Re: GUI crashes on opening 'Populate variables'
Hi bartcuijpers,
I'm have recreated the issue and it will be fixed. Thanks for reporting!
