0.8.20 - Line 3314 Error: Subscript used on non-accessible variable
acbaldwin
Post by acbaldwin »
Just updated and get this error within twenty seconds of opening up FFAStrans. Not sure if it's related to a workflow - the current one open is this:
Error seems to occur even if I'm doing nothing, and reoccurs soon after I OK it.
Going back to 0.8.0 and everything works fine.
Re: 0.8.20 - Line 3314 Error: Subscript used on non-accessible variable
Hi acbaldwin, thank you for using FFAStrans and welcome to the forum! :-)
Does this happen on all workflows or is it just one? And if so, can you please export your workflow and send it so that I can investigate?
acbaldwin
Post by acbaldwin »
Apologies, I forgot to check back! I am currently on .80 and out of nowhere none of my watch folders will watch, even after a bit of troubleshooting. I went to grab the new .8.2.2 version but now both of my development PCs recognize the .7z file as containing a virus. I haven't run into this before with FFastrans. I am able to download older versions like .0.8.0.3 without issue.
Once I get this working I will share my workflows with you.
